TractorLinks.com
Re: Steering issue 931B?
Bob/Ont
05-19-2013 06:49:10
You can't adjust the steering linkage for roller wear. The cam will only push the valve so far then it's concentric. You need to take both steering valves out and replace the rollers on the valve spool ends. Then when reinstalled adjust the steering rods so there is 0.027" clearance between the cam and the roller. Then adjust the brakes as tight as you can, and make sure there is no peddal travel. If there is, back off the adjustment 1 1/2 turns and shorten the brake links as short as you can and still get the pins in. Then adjust brake bands to get correct peddal height. After this the machine should steer with a light toe pressure.
Later Bob
Stick welding
05-19-2013 07:30:14
 Re: Steering issue 931B? in reply to Bob/Ont, 05-19-2013 06:49:10
Thanks Bob. I need to dig a hole first to pump water into but I guess taking the steering valves off is next on the agenda.
