Anonymous-0
I think I finally have the fuel problem solved so on to the next issue. I had both brakes working great but late last year the left brake started acting up. What's odd is the right brake has a flat spot on the roller for the steering clutch valve and the left brake doesn't unless is wore down evenly. I shortened the linkage to get the left brake to kind of work (cause I had a job to do and had help)but I think the problem is more with the steering clutch. If the steering clutches aren't fully engaging, does that make the brakes not want to do much? In Reverse the left will work after a couple seconds but it's almost like a delay before it grabs and you have to push it all the way to the floor. Can the steering clutch valves stick and should having new rollers installed get the brakes working good again?
