Case rear end
Checking up on the online parts site the part numbers for the ring and pinion are different which mean the parts are not the same,the carrier bearings are the same,the differ might just be the ratio,count the teeth on the ring and pinion of both and you can compare,if the ratio was close you may be able to live with it.
AJ
