Yesterday's Tractor Co.
Shop Now View Cart
Re: Correction 1970 Cat D6C Value + Pins/sprockets question
05-04-2013 03:40:32
Most Cat or Deere construction dealers have someone who will inspect undercarriages,as do shops that do undercarriage work. They will give an accurate estimate of the condition of the whole undercarriage, including pin and bushing wear,sprocket wear,roller condition etc. If the rollers and idlers are only partially worn, and the pins and bushings haven't been turned,and there is decent rail height,you may luck out and get by with a pin and bushing turn and a new set of sprockets, which will give you about 2000 hours of operational life before a major expense depending on the soil conditions you operate in. If nothing else the inspection report will give you a good bargaining chip to negotiate a price on the tractor as well as knowing what kind of life the bottom has left in it and what you will need to spend.
