Anonymous-0
I put the new check valves in the transfer pump but didn't get to see if it solved the loss of power problem. The old ones didn't look bad but who knows? I had to take the bolts out of the oil cooler and move it down just a bit so I could get the bottom bolt out of the transfer pump. I put everything back together and it started right up and I ran it for 5 to 10 minutes.
Looked good and no leaks so I drove it about 100 yards and checked again for leaks. No fuel leaks but oil was dripping. Closer inspection showed that the top tab the oil cooler bolts to had pulled off. I don't know if the heat from warming it up caused the cast iron to break like that or not. I think it's a 5/16" bolt and I was careful to tighten the 2 bolts evenly. Anyway I need to fix it. Is the attachment point for the oil cooler a separate piece or part of the engine block? It's a non turbo with just the small round oil cooler. The bottom of the injection pump also bolts to this piece. Being that it's cast iron, it's not the easiest thing to repair, especially if I have to do it in place on the machine. Probably best to replace it if possible rather than trying to fix it in place on the side of the engine. If it is part of the block, can it be drilled and tapped deeper into the housing? Your help is appreciated.
