TractorLinks.com
Re: TD15
Jean G
04-20-2013 13:48:28
I haven't notice any heating or aluminium colour in the oil as of yet. i will however replace the filters and have a closer look.
Meanwhile we did replace the starter as it was filling with oil. After replacing it, we noticed oil was still coming out of it. We then cleaned the breather out as it was clogged solid. Seams to have solved the oil heading to the starter. As far as I know that is when the leaking from the breather started.
I'll have a look for the scavage line to see if it's crushed.
Any idea on how much could possibly cost replacing seals on converter ?
Jason Weir
05-13-2013 08:50:12
 Re: TD15 in reply to Jean G, 04-20-2013 13:48:28
Jean where was the breather and scavenge line located - we've got a td-15 with the same problem and need to check the breather and scavenge line.
Just had the converter resealed and it didnt fix the problem...
Thanks,
Jason
Jason Weir
05-20-2013 12:26:16
 Re: TD15 in reply to Jason Weir, 05-13-2013 08:50:12
Found the screen filter in the scavenge line plugged up solid - cleaned that out - everything dried up..
jm.
04-20-2013 17:02:31
Do not know where you are located but one of the best 15 torque rebuild guys is close here in Tenn. You will have trouble finding parts and what is out there are expensive. If it was bad enough to flood the starter expect to be pulling it before long. The longer it goes the more it will cost. There is some aluminum parts running close to metal parts and if they touch things go fast.
