could someone please help me? i bought a 74 model 580b with 1400 auctual hours, it had not been started for 2 years, fired right up runs great problem is no steering.. sent steering pump to hyd. rebuild shop they said it had been run dry of oil and beyond repair found a used one put it on now it will barley steer with front wheels off the ground. can or should the releif valve inside the resevoir be adjusted? if so where do i start or should i send it to repair shop for proper setting? doesen't seem to be mush pressure when i disconnect any line at cylinder or spool. anything else i need to do or check?
thanks in advance i'm new here great fourm with lots of help
