Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: case 580b pushing power
Case Nutty 1660
04-16-2013 06:31:23
depending on the type of ground you are on yes it may only spin them in 1st gear the type of hoe you have will make a differance also a extendahoe and large bucket adds extra weight if you have good rim pull in 2nd for loading on a trailer I would say it is OK on those models 2nd was used for loading out stock piled material and easier digging areas such as sand so as not to get so much wheel slippage, in hard digging with good traction 1st works well, one thing to remember is use your bucket rollback and lift to fill the bucket as you are pushing into material, spinning the tires is not really the best idea or needed if you can help it, also make sure you are getting full throttle as 50-100rpms on the top end really make a differance in push power with a torque convertor drive, also always let the sytem warm up a bit with the 4 speed in neutral with the shuttle lever in FWD or REV this not only will lube everthing and give faster warmup it will extend the life of the shuttle clutches many hours rather than just starting it up for the day and throwing it into FWD or REV and standing on the throttle to make it move, we sold hundreds of 580's in the 60's and 70's every year great machines
