TractorLinks.com
Re: D2 sealed chains???
Old Magnet
04-13-2013 08:52:10
I don't believe anyone is producing D2 SALT tracks but I've heard they are available dry.
D3 SALT tracks are available, same 6.125" pitch but you will have to change to D3 sprocket rim because the pin diameter is 1.85" where the D2 is 1.69".
smallercrawler
04-13-2013 15:36:21
 Re: D2 sealed chains??? in reply to Old Magnet, 04-13-2013 08:52:10
OM-good to see your post, missed the knowledge you share!
Billy NY
04-13-2013 11:04:30
Old Magnet, good to see you over here ! Hope all is well out your way !
Who was the fellow that did a complete ground up build of a D2 up in Canada, that converted to D3 U/C ? Probably archived in ACMOC or ACME, but the photos were really informative. It was a great thread to follow. He changed to the D3 pitch, and had to do some modification to either the track frames or the rollers to get the right fit,I really forget now, but was a nice job, worth doing as it was not all that complicated, mostly work, of course that was a really nice shop with machining capability, the benefit was now you can use D3 components which are available, for the longest time it seems no new U/C parts were available for the D2.
Old Magnet
04-13-2013 19:26:23
 Re: D2 sealed chains??? in reply to Billy NY, 04-13-2013 11:04:30
Yes, I have copies of the pictures of D2 track truck modifications. Problem is if you use the D3 rollers they are a much smaller diameter than D2 originals so a spacer bar is required to make up the difference.
