TractorLinks.com
Re: Cat 3306 Fuel Pump
AC Tim
04-08-2013 06:50:06
Hi Bob,
I borrowed the piston/pump removal tool (8S2244). Is it ok to remove the #2 piston on the pump directly to check for any wear, or are there steps to the removal/installation process that you would advise doing first. It looks pretty straight forward, but I am worried looks may be deceiving.
The Best
Bob/Ont
04-08-2013 14:24:57
 Re: Cat 3306 Fuel Pump in reply to AC Tim, 04-08-2013 06:50:06
Tim, you can buy a spring if that is all you need. First take the big plate off and see what is wrong. Then you can take out the #2element.
You need to take it apart to change the spring if it is needed. Get a dish of fuel, the parts will get dirty from you handeling them, wash off and assemble the barrel and plunger under fuel to keep clean.
Later Bob
AC Tim
04-09-2013 18:54:06
 Re: Cat 3306 Fuel Pump in reply to Bob/Ont, 04-08-2013 14:24:57
Here is what I found in the pump. Looks like the plunger sheared off. The spring was good. My problem is I cannot get the bonnet off the #2 pump piston. I have the 8S2244 extractor and the 8T5287 wrench, but neither of these fit over the 25mm? bonnet. Does anyone know what tool is needed for the bonnet for that pump?
Thanks Much
AC Tim
04-08-2013 17:38:00
Thanks Much Bob,
Will let you know how it goes.
The Best
