Yesterday's Tractor Co.
Shop Now View Cart
Re: Cat 3306 Fuel Pump
04-06-2013 19:16:29
Turn off the fuel and remove the big plate, might find a broken spring. Not sure you can buy the spring only but will find out.
Later Bob
AC Tim
04-06-2013 19:39:07
 Re: Cat 3306 Fuel Pump in reply to Bob/Ont, 04-06-2013 19:16:29
Bob, Thanks Much!
Is there anything to be careful of when taking off the plate. Any parts that can fall out etc.?
04-06-2013 19:43:46
 Re: Cat 3306 Fuel Pump in reply to AC Tim, 04-06-2013 19:39:07
I think the only loose part is a plastic relief valve and spring. The pump housing is lubricated by and full of diesel fuel. What is your serial#?
Later Bob
AC Tim
04-07-2013 07:45:03
 Re: Cat 3306 Fuel Pump in reply to Bob/Ont, 04-06-2013 19:43:46
Serial number is 7N2058.
A picture is attached as well. Thanks for your help.
04-07-2013 08:44:10
 Re: Cat 3306 Fuel Pump in reply to AC Tim, 04-07-2013 07:45:03
Thanks, I think you might do well to remove the pump Tim. It would be easier to drill the broken manifold studs. To remove the pump take the TDC plug out of the flywheel housing and the 9/16"hex plug from the odd shaped housing rear of the plate on the pump. Rotate the engine untill the shank of a new 1/4" drill bit will go down the hole in the pump and drop into the slot in the camshaft. Check the hole in the flywheel is inline with the hole in the housing and a 3/8"NC bolt will thread into the flywheel. You are now timed up. Take off front cover and pull gear off tapered shaft. When installing pump amke sure bolt will go into flywheel and the #1 valves are both loose. Turn pump shaft untill drill drops into slot, mount pump and install gear.To install gear torque bolt to 100 Lb Ft. You need a special socket to take nut off of pumping element, fuel shop might be best way to go.
Later Bob
AC Tim
04-07-2013 08:47:40
 Re: Cat 3306 Fuel Pump in reply to Bob/Ont, 04-07-2013 08:44:10
Thanks Bob. Will go with your suggestions.
The Best
