Re: Loose Track Pad Bolts/Won't tighten
LOU from Wi.
04-02-2013 13:28:05
Don"t waste your time and enetgy trying to re-tighten old pad bolts. Get new ones fron Berco. If the holes are worn out ot ovaled, pull off a solid pad and make it a pattern when you weld up the worn pad. Will last until its worn out and bent down. Did our tracks using J D 350 pads. Had to cut off 1/2 inch from both ends. Weld holes up, grind hole area flat again and use original O.C.46 pad as a pattern. drilled and installed em. Works for us. LOU
