Yesterday's Tractor Co.
Shop Now View Cart
Re: Loose Track Pad Bolts/Won't tighten
04-01-2013 18:25:24
Just came back from the shop. The threads on the bolts on the one pad are wore out good. So i will be replacing them. I just happened to find four bolts and nuts in the parts room.
The other pad I put a cheater pipe on a socket and tightened those ones up.
I just have to figure out a way to get the old bolts off the bad pad. I dont have torches so might be spending an hour or so with the grinder.
Stick welding
04-01-2013 22:08:31
 Re: Loose Track Pad Bolts/Won't tighten in reply to Case450, 04-01-2013 18:25:24
Did you use track bolts? You don't just put a snipe on a wrench and use standard bolts. You tighten to a lower torque (for the size of bolt) and then turn them an additional 1/4 to 1/2 a turn for proper final torque. A dealer or undercarriage shop will have the proper torque specs. Someone on here that does undercarriage probably knows as well.
04-02-2013 04:15:19
 Re: Loose Track Pad Bolts/Won't tighten in reply to Stick welding, 04-01-2013 22:08:31
Yeah I installed brand new track bolts when I rebuilt the undercarriage years ago. Dont know why these two pads are loose. Its done, just gotta deal with it now.
steve n carol
04-07-2013 19:15:07
 Re: Loose Track Pad Bolts/Won't tighten in reply to Case450, 04-02-2013 04:15:19
Where are you located? I have a bunch of used track bolts and nuts if you want, for the cost of shipping. I also have some tall tanks, 100' of hoses and cutting torches I'd sell ya, at a fair, in Southern Cal.
