TractorLinks.com
Re: 3204 check valves
Bob/Ont
04-01-2013 18:02:54
If you can clean it and it isn't coming apart it should be fine, if not replace it. That stuff might be in the check valves too. It is very common for the check valve flaps to break up. You are getting fuel just not enough for any power. Later Bob
Stick welding
04-01-2013 18:08:51
 Re: 3204 check valves in reply to Bob/Ont, 04-01-2013 18:02:54
I got the new check valves and all the o-rings to reassemble. It cost $15.99 at Union tractor. Trying to find the screen assy. took forever cause it wasn't listed with the transfer pump and every other picture of a transfer pump showed a hand primer that I don't have. Finally found a good picture and I should have the right parts.
dpendzic
04-02-2013 11:46:46
 Re: 3204 check valves in reply to Stick welding, 04-01-2013 18:08:51
this is what I have
Stick welding
04-02-2013 15:31:10
 Re: 3204 check valves in reply to dpendzic, 04-02-2013 11:46:46
That's one of the parts diagrams I got. It's stupid that the screen and hex fitting that attaches on the pump isn't shown. After much looking finally found the diagram with the screen and hex fitting.
RodInNS
04-02-2013 19:05:08
 Re: 3204 check valves in reply to Stick welding, 04-02-2013 15:31:10
Mabey the cat guy wasn't so stunned after all.....
Sorry, I couldn't resist that, but you get my point?
Rod
Stick welding
04-02-2013 20:41:12
 Re: 3204 check valves in reply to RodInNS, 04-02-2013 19:05:08
We found the primary fuel filter right away. The guy helping me has sold Cat parts forever and he thought it was dumb that the screen and hex fitting isn't shown with the pump or the fuel lines.
