will jd 350 tracks interchange with 440 crawler
I understand that the pitch is the same but 440I bushings are smaller in diameter than 350 bushings so you have to use 440I sprockets with 440I rails.
You might try asking at jdcrawlers dot com.
Bryce
Lets put it this way, they'll fit fine if things are worn out enough. There's a right way to do it and a not so right way. The not so right way works for me, but then, I'm a cheapskate.
