| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Mitsubishi DB2G
[Return to Forum]
| Author |
[Modern View]
| CBBC
02-27-2013 19:56:43
70.79.230.41
Hi I'm looking at a little DB2G with the pyramid cleats. It seems to run well. The engine had some work done on it - top end all redone. The rollers, and idlers, pins and bushings seem good, but the drive sprokets are probably original - they are worn but have about 3/16s flat on top. I am confused about a couple things. There is a hydrolic filler and dipstick by the break / clutch peddles. This is for the transmition - all looks well here - clean and to the right level - 10w oil??? He said there was a 5 disk clutch here also - is it wet or dry? There is a hydraulic reservoir onder the right armrest area with the blade controls. This is for theblade controls - 46W hydrolic oil? Under the seat is another short dipstick and a breather cap in a Y tube. This goes to the rear end - is it a differential that runs the final drives? Is this area connected to the front reservoir?The dip stick here was dry but was a bit rusty. Opperationally is seems pretty tight - and I've run some loose machines. It pushes well for the light weight - and I was in mucky slopp. Its a 1993 he said. He rewired the lights and gages, but no hr meter. Hoses have been replaced, both steering breaks(or whtever they are) worked well- no sticking or jerking. When moving forward or backward the main brake will stop the machine evenly. Transmition seem to shift smooth. No obvious leaks. My only real concearn is the dry rusty rear dipstick. I would really like to run it for an hour befor I buy it - to see how it is when hot... He is asking $10000 - which may be a bit high? Any thoughts or things I should look out for? Thanks, Grant |
[Reply] [No Email] | |
| Stick welding
02-27-2013 22:47:34
96.53.210.246
Re: Mitsubishi DB2G in reply to CBBC, 02-27-2013 19:56:43
| Are the sprockets worn down and/or broken off or they still have 3/16" on the tips? If the latter, they still have a little life left. When they get pointed and start breaking the tips off, they are done. I use universal tractor fluid in my Cat for the hydraulics. It says on the pail it can be used for hyd. systems. I use Esso Cat spec. oil in the trans. In my MF tractor I use the MF Perma-tran and find it works the best. The pyramid pads are for working in the muck or rice fields I think. They're self cleaning but aren't the best for working on drier ground. The wider the pads, the harder it is on the undercarriage. |
| CBBC
02-28-2013 11:00:40
70.79.230.41
Re: Mitsubishi DB2G in reply to Stick welding, 02-27-2013 22:47:34
| Thanks |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
