TractorLinks.com
Re: JD 310 Backhoe Hydraulic Hose Problem
marloweg
02-20-2013 19:44:07
if you were not using the hoe how could a hose burst the only hose with pressure on wold be the supply hose to the spool and then the return line so no hoses to any rams would have any pressure on them and if the hoe was in lock position there was no pressure on the lower ram unless the leaver got pushed or pulled
Outback Rider
02-21-2013 06:54:42
 Re: JD 310 Backhoe Hydraulic Hose Problem in reply to marloweg, 02-20-2013 19:44:07
Yes, in order to push the crowd out, lever was moved, not sure if I accidently moved the boom lever causing the burst....
Can't tell yet which line is blown...
