Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Final Housing Sealant ?
[Show Entire Topic]  [Return to Forum]
NCWayne
02-13-2013 18:35:37
69.40.232.132
Most gaskets, by design, aren't supposed to require any help to seal, so no sealant is recommended. That said "design" and real life take different paths waaaaayt too often and no extra sealer means leaks. That said, what I always use is Permatex Ultra Blue or Ultra Copper (for higher temp areas). Unlike regular silicone, which some love to over apply, you can use your finger to smear a really thin coat on the housing (or gasket) and when you bolt it togther it doesn't squeeze out into big gobs like the regular stuff does. Over the years I've been back into machines I've repaired bfore, to fix something else, and have yet to see one of the joints I made up like this leak or cause any problems with the operation of the machine. I can't say as much for the ones where someone in the past gobbed silicone on and tightened everything up. In those cases I've seen everything from turbos going out from oil starvation because the supply side was nearly plugged, to engines shutting down from silicine slug that were squeezed through bolt holes getting sucket into a fuel line, and quite a few things in between.
As far as the recommendation to use weatherstripping cement, prepare to hear the next guy into the machine CUSS you and your ancestors both past and future if you do that......I've done it to others kith and kin so I speak from experience there.....LOL. The only time I would recommend that is in an extreem situation where nothing else has worked, and, bad as I hate to say it on just about any oil pan or valve cover gasket made out of natural cork. In the case of the cork using it will cause the next guy to cuss you when he has to clean it off, and not using it will get you cussed by the owner when it starts to leak in a month after the cork 'takes a set' and the bolts get loose. In the end all I can say is whatever your choice, good luck.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
