Yesterday's Tractor Co.
Shop Now View Cart
Re: 2500# cyl in a 2700# system
01-27-2013 23:19:21
Well the machine is sort of a fixer upper (the only reason it was priced low enough for me to buy it). 2 bad cylís on the hoe, multiple cracks in the backhoe and generally just behind on maintenance. Due for all new fluids and filters. Needless to say Iím on a budget and Iím just all around cheap to begin with. I called cat about the cylís and they are no longer available. Looked around a bit and a used one is around 1000$-14000$. I thought about just replacing the barrel on mine but the honed tubing is sold by the inch and a 48Ē piece was more expensive than just buying a total new cyl from prince. Plus I would have to cut threads into it to screw my packing into which would not be cheap. So that is why I bought a utility cyl for around 330$. If you know of a hydraulic shop that can re-barrel a cyl affordably Iím all ears because I still have the bucket cyl to do. The previous owner couldnít get the packing gland to unscrew so he took a torch to it and cut the cyl apart around the rod.
01-29-2013 21:17:59
 Re: 2500# cyl in a 2700# system in reply to gusbratz, 01-27-2013 23:19:21
Don't know where your located, but you might try giving SHP and HCR both a call. Both are somewhat local to me, with SHP being about an hour or so South into SCI, and HCR being about an hour North, and I've done business with both numerious times over the years (SHP the most). Both places do good work at reasonable prices. I say that dependent upon what you call reasonable, cause a custom cylinder can often be more expensive than a standard, off the shelf one, but still less than one from the OEM. Hope this helps, and good luck.
