Yesterday's Tractor Co.
Shop Now View Cart
Re: 2500# cyl in a 2700# system
Stick welding
01-26-2013 23:34:24
Mixing and matching cylinders components sounds like a recipe for problems. Is the Prince cylinder a threaded end, tie rod or cir-clip? That's the most likely place for a cylinder to let go if over pressured. A backhoe requires an industrial cylinder, not a utility cylinder and it is common to hit the relief valve. Are the inside dimensions(length and bore) identical? Is the rod the same diameter? Unless they're identical in every way, I don't see how you could interchange parts. Why not just get a new barrel made to match the scored one?
