Yesterday's Tractor Co.
Shop Now View Cart
Re: Magnatrac mini dozers
Randy Corlew
01-17-2013 19:42:28
I was just wanting to offer some insight on skidders vs the Magnatrac.
Skidders are more expensive HP vs dollar I believe (New) - Someone tell me different. Strucks are high new but so are the skidders.
Gas vs Diesel engines? Home owners can work on the gas much cheaper and easier. Struck is pretty easy to work on. Many Skidders like the Bobcat have a ton of electronics that you have to take to the dealer if you have a problem. Struck has straight hyd. control valves not all the electrical switches in the handles.
Again the skidders are a ton faster but those are built for the construction market not the homeowners. Again I see the Struck as a large homeowners crawler where a bigger mid range is not pratical and where a 25 hp compact utility just wont get it done. Tight areas where power is needed is where the Struck machines shine. Get out of that area then I would have to say don't get the struck. If you had 20 acres - don't get the Struck because travel time is at best 3 mph with overdrive. Again do the research and make the decision based on your need and area.
