| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: JD 450C hyd pump problem
[Return to Forum]
| Author |
[Modern View]
| Todd Asbill
01-14-2013 19:29:11
69.46.60.148
My recently purchaced jd 450c 6 way blade. New hyd pump locked up and broke shaft that drives the pump. I took Hyd pump apart and found that the gears had been shaving the inside of housing. I found aluminum slivers from housing all in the gears so I assume that is what caused it to lock up. The question is what is causing the pump to do this? John Deere are really proud of those shafts is there any aftermarket shafts out there. |
| Roy Suomi
01-16-2013 16:55:11
76.190.196.2
Re: JD 450C hyd pump problem in reply to Todd Asbill, 01-14-2013 19:29:11
| Years ago I ran into a similar problem..If memory serves, there was a relief valve or poppet valve that was hammered and pieces parts were flowing thru the system causing the pump to self destruct.. Pull the control valve out and check all reliefs and poppet valves for problems..The return filter was removed at some time and junk was being recirculated..Also check the system relief for stuck condition.. This relief is on the inlet to the valve in the end cover.. |
| Todd Asbill
01-15-2013 06:17:07
69.46.60.148
| This is the second new pump the first one did same thing so my first thought was a faulty pump. Then when the second pump did same exact thing now i think there may be a problem else where. |
| Roy Suomi
01-23-2013 16:58:06
76.190.196.2
Re: JD 450C hyd pump problem in reply to Todd Asbill, 01-15-2013 06:17:07
| I don't remember , is it a Gressen valve ?? Try calling Surplus Center in Nebraska. They have some real sharp customer service people that know their stuff.. Maybe they can help.. |
| Todd Asbill
01-15-2013 17:49:14
69.46.60.148
| Possibly found the problem. This dozer according to the books requires a 1750psi relief valve the valve that is in it is a 2250psi valve. Now I am looking for a place to get the 1750psi relief valve. any ideas where to start? according to my local JD dealership they are not available. |
| kyhayman
01-14-2013 20:04:14
99.197.64.57
| Shaving of the pump body like you describe is a pretty good sign of bearing wear. Lets the gears track looser and looser. The more shavings the more wear. Good systems flush, and a trip to the pump shop. As to the shaft, perhaps a driveline shop or machine shop can weld and balance the shaft... or a used one. For the pump, I'd take it to a good hydraulics shop and have them go through it. They may be able to repair or source your shaft as well. |
| Lloyd East
01-16-2013 14:57:41
75.89.139.198
Re: JD 450C hyd pump problem in reply to kyhayman, 01-14-2013 20:04:14
| My brother and i have a 450c loader that did the same thing three times. i think it must have the same problem. First time it broke the shaft and second time it broke the center part of the pump. My brother bought another pump off the internet and put it on there and it blew the threads out of the outlet of the pump. I would think you could rebuild the pressure relief valve. It is probably just stuck. That is probably what is wrong with ours but we haven't worked on it any more. |
| Todd Asbill
01-19-2013 17:43:46
69.46.62.203
Re: JD 450C hyd pump problem in reply to Lloyd East, 01-16-2013 14:57:41
| Its fixed. Someone had had the relief valve out at some point in time and did not have the poppet at the bottom of relief valve in correct. The system was over pressurizing causing the pump to lock up then the shaft would break. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
