hi,i am new to this and I don't know if any one can shine any light on a problem with 1985 3cx no 313610, i have been using this machine for 6 month with no problem but now it will not go forward or back, the problem started when using the dump clutch pedal, also i can not select the gears easy in neutral , some times it trying to go but with no power or very little to the back wheels, oils are all good, the transmission is the type with filter in the sump in the gear box and the f/r shuffle lever on the left i think its the b/w gear box no 13027/585/3180 if this helps, hope you can help as i would love to get the old girl sorted, any help from any one would be very grateful, regards and many thanks martin
