Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 1985 jcb 3cx no forward or reverse
wibbly
01-03-2013 14:12:56
hi aj, i have tried to find a manual but with no luck, I have worked the machine for about four hours today and it definitely seems under power to what it was. I did not quite understand what you meant about the adjustment do you mean the clearance between the mechanism that releases the valve and the valve pin when the dump pedal is up. Mine when the pedal is up I can press the valve pin in by hand as it feels like it is sprung loaded against the mechanism and I can gain roughly 10 thou movement away from the mechanism into the box would this be correct?
Regards
Martin
