Yesterday's Tractor Co.
Shop Now View Cart
Re: 1985 jcb 3cx no forward or reverse
01-02-2013 15:18:23
I got things the wrong way round,it should have 10t clearance when the pedal is pressed.if you have the manual it will tell you how to test the pressures and do a stall test,the adjustment of that valve is the only adjustment that can be made on that unit.
01-03-2013 14:15:25
 Re: 1985 jcb 3cx no forward or reverse in reply to AJ., 01-02-2013 15:18:23
hi aj, i have tried to find a manual but with no luck, I have worked the machine for about four hours today and it definitely seems under power to what it was. I did not quite understand what you meant about the adjustment do you mean the clearance between the mechanism that releases the valve and the valve pin when the dump pedal is up. Mine when the pedal is up I can press the valve pin in by hand as it feels like it is sprung loaded against the mechanism and I can gain roughly 10 thou movement away from the mechanism into the box would this be correct?
