Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: 1985 jcb 3cx no forward or reverse
[Show Entire Topic]  [Return to Forum]
AJ.
01-02-2013 01:50:55
92.4.133.44
If yours has the Borg Warner shuttle the clutch cut out is operated by a mechanical linkage,secure the machine,go under it in front of the left back wheel,look up at where the F/R cable connects to the shuttle,have a second person in the seat to operate the dump valve and you will see it push the valve in,the valve is spring loader to return and there should be .010" clearance between the valve and the plate that pushes it,to adjust the clearance loosen the jam nut on the bolt that screws into the valve,screw the bolt it in or out to get the right clearance,make sure all the linkage is free,give that a try and see how it goes.
AJ
Ps forgot about the gear change,that 4 speed box has its own oil,80W 90 gear oil,make sure the parking brake is releasing and the main brakes are free.
This post was edited by AJ. at 09:56:53 01/02/13.
[Reply]   [No Email]
wibbly
01-02-2013 13:30:08
92.15.175.227
Re: 1985 jcb 3cx no forward or reverse in reply to AJ., 01-02-2013 01:50:55
hi aj, thanks for your reply. You are a godsend to us kind of blokes. I was reading some of your previous forums from 2006-2009 regarding someone having a similar problem. I read up on this in the early hours of the morning, printed off some of your forum sheets, went out this morning and tried this before reading this forum and got the old girl working. One question when my dump pedal is depressed my valve comes out of the box on the dump valve and when released it pushes the rod on the dump valve in. How I achieved approximately 10 thou clearance was pressing the rod in the middle of the dump valve as far as I could in by hand then adjusted the nut on the valve rod to approximately 10 thou so I could just rattle it when the pedal was up and the rod was in the box at its furthest point. On depressing it it lets the valve rod come of out the box to drop the torque converter pressure but the valve rod seems to work the opposite way dropping pressure when the valve rod protrudes out of box is this correct in my understanding? On the point of 80/90 EP oil the gearbox is obviously the part that sits behind the box with the oil pan on with a level plug on the side where you fill it to. I have now got about 70% forward and reverse push power I am not sure that it is delivering the correct amount of power as today I was using the machine with the four in one bucket open grading back in second gear on a little bit of soft ground and once it had a slight amount on the bucket it really did not want to pull anymore it was not wheelspinning I had to go down into first to do this job it seems a little under powered I wondered if there is any other adjustment I can do to increase the power. when i say power i do not mean engine power but gear box torque
Regards
Martin
  [Reply]  [No Email]
wibbly
01-03-2013 14:12:56
92.15.133.36
Re: 1985 jcb 3cx no forward or reverse in reply to wibbly, 01-02-2013 13:30:08
hi aj, i have tried to find a manual but with no luck, I have worked the machine for about four hours today and it definitely seems under power to what it was. I did not quite understand what you meant about the adjustment do you mean the clearance between the mechanism that releases the valve and the valve pin when the dump pedal is up. Mine when the pedal is up I can press the valve pin in by hand as it feels like it is sprung loaded against the mechanism and I can gain roughly 10 thou movement away from the mechanism into the box would this be correct?
Regards
Martin
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
