| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Cat 955L leaking transmission seal
[Return to Forum]
| Author |
[Modern View]
| Michael Sidon
12-27-2012 16:03:35
69.17.175.2
how do you replace the seal. Does the motor have to come out? |
| Robert Plumadore
01-04-2013 18:19:04
67.191.180.16
Re: Cat 955L leaking transmission seal in reply to Michael Sidon, 12-27-2012 16:03:35
| if it is a 995 L you can pull the torque or tranny with out touching the engine. all 955 K & Ls have a flex coupling between the engine and TC. replacing the seal is a simple job I can scan the article from the service manual. there is a wear sleeve that can be installed on the TC input flange to take care of any wear on the seal surface |
| Michael Sidon
01-04-2013 20:12:37
69.17.175.2
Re: Cat 955L leaking transmission seal in reply to Robert Plumadore, 01-04-2013 18:19:04
| Thanks I'll give it a go. Mike |
| Fritz Maurer
12-28-2012 14:54:41
216.137.138.146
| Naturally, try what Bob says first. I didn't think taking the blocks out would give enough room to slide the flange off. |
| Bob/Ont
12-28-2012 11:12:59
70.26.65.149
| If you mean the seal in the front of the torque converter just take out the coupling. Drill and use sheetmetal screws to pull it out. Make sure the shaft isn't wobbeling around on failed bearings. Can get sleeve to cover worn groove in flange. Later Bob |
| Michael Sidon
12-28-2012 13:16:25
69.17.175.2
Re: Cat 955L leaking transmission seal in reply to Bob/Ont, 12-28-2012 11:12:59
| There doesn't appear to be a coupling just a spline from the engine direct to the tourque converter. If I took a picture could you confirm? Mike |
| Bob/Ont
12-29-2012 09:12:27
70.26.65.149
Re: Cat 955L leaking transmission seal in reply to Michael Sidon, 12-28-2012 13:16:25
| Yes. there should be two discs connected by four biscuits bolted between them. Later Bob |
| jm.
12-28-2012 05:58:18
75.105.128.54
| Are you sure which you are talking about. Transmission or torque convertor? Where is the leak? |
| Fritz Maurer
12-27-2012 20:48:21
216.137.138.146
| As you're taking the engine out, take note of any shims under the rear engine mounts. These shims are for locating the rear of the motor, to minimize the mis-alignment of the drive coupling. Remove the drive blocks and inspect them closely. Any cracks or dry-rot, replace them. They're pretty dear at $80 apiece, but remember, they never break when the weather is dry, warm and sunny. You have to fix it where it breaks, unless you happen to have something bigger you can pull it around with. |
| Billy NY
12-28-2012 09:21:13
72.226.79.200
Re: Cat 955L leaking transmission seal in reply to Fritz Maurer, 12-27-2012 20:48:21
| Yes, make sure to take note of those shims, if misaligned, those drive blocks will come apart in short order, recalling from memory, while running a 955, that just had an engine overhaul, this happened 2x, once with a line of trucks to get loaded, and that was the cause. |
| marloweg
12-27-2012 19:45:06
184.157.219.229
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
