Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Case 26 Backhoe on a DO MOR Tractor
AJ.
12-25-2012 15:57:16
There is an o'ring at the top of and bottom of each spool valve,remove the cap from the reservoir to relieve any pressure,clean around the top end of the valve and the cap on the bottom,remove the clevis pin and disconnect the rod from the valve,remove the two bolts from the bottom cap and remove it,have an oil catch underneath,if its only the top o'ring you need to replace,push down the valve past the o'ring and replace the ring,if you are going to replace the two you will have to remove the spool valve,both o'rings are marked in the parts drawing by a red square.
AJ
lenray
12-26-2012 07:48:27
 Re: Case 26 Backhoe on a DO MOR Tractor in reply to AJ., 12-25-2012 15:57:16
Thankyou for the information fellas---Very helpful.
This is an older hoe installed on a 1970s era DO MOR tractor that was made in Manistee, Mi.
