This message is a reply to an archived post by Rob R on July 23, 2011 at 04:25:18.
The original subject was "Re: TD8E steering issue".
Hello, I am hoping you might be able to help me some with a td8e I just bought. 3013 serial number. It feels as though it is really lacking power. Sometimes it doesn't want to turn either way, it just sort of stops. When pushing against trees it will just stop. Also, going up the trailer ramp the other day it couldn't get up. This is all in first gear. Putting the throttle all the way up helps some. The other problem it has it sometimes when I pull back on the right stick it just doesnt do anything. Although, if I pull both sticks back and let off the left, it will then turn. Any ideas?
