john deere 410
Anonymous-0
I have a John Deere 410 back hoe that is stuck in high range. I'm looking for suggestions on the best way get out high range.
Try picking up the rear end with the backhoe stabs,then have someone rock the wheel while you try to move the gear shift. If that doesn't work you may have to take the top off the transmission and try moving the rail.
Nope.. Not power shift.. Just Clutchpack.. If it's a straight 410, you pull the plate that the shifters come up thru.. Look down there and you might find a piece of metal missing on the end of one of the shift shafts that push or pull the shift forks..It's very common.. I just fish out the pieces and fabricate another piece , then weld it to the shift shaft.. Outerwise the correct repair is to split the tractor behind the reverser and change out the shift shaft..Quite a little undertaking if you don't have to..I've done this about half a dozen times with good results..With that piece missing , you can't move the shaft to get it into low range.There are "interlocks" on those shafts so it can't do 2 different gears at the same time..
