TractorLinks.com
Re: g188 diesel smoking
AJ.
12-20-2012 07:54:07
It may very well have injectors that is not atomizing the fuel properly,they do need service every now and then and once you done them you will know better where you stand,if you do have the glow plug give it a check,take off the fuel pipe attached to it,use a piece of soft hose,put one end up against the nipple where the pipe goes and the other in your mouth and try to blow through it,if you feel the pressure going away the plug is leaking.if its solid its ok.
Good luck
AJ
