Yesterday's Tractor Co.
Shop Now View Cart
Re: new crawler.
12-13-2012 10:20:02
Well you better read the spec's for the 6010 5P= because it is a 11010 class rod!
Stick welding
12-13-2012 10:39:24
 Re: new crawler. in reply to DGH, 12-13-2012 10:20:02
I currently work...
in a welding supply store with the Lincoln welding consumables book right in front of me. The 6010 IS the rod classification!!! 60,000 psi tensile, all position with a cellulose coating. AWS classification E6010. I've also been a licensed interprovincial red seal welder for close to 30 years. I think you should have your facts straight before you try to correct anyone. LoL
12-15-2012 10:12:53
 Re: new crawler. in reply to Stick welding, 12-13-2012 10:39:24
Drama Queen still has a job?????????
12-13-2012 11:09:29
Well get yourself a 6010 rod and a 6010 5P+ rod and try to cut each on with some cutting pliers. You will find the 5P+ rod is much harder!! A normal 6010 rod and a 6010 5P+ rod are not the same!!
Stick welding
12-13-2012 12:25:50
 Re: new crawler. in reply to DGH, 12-13-2012 11:09:29
It's still a 6010 class rod. You don't measure the strength of a welding rod but how hard it is to cut with side cutters, otherwise you might as weld everything with hard facing rod.
Stick welding
12-13-2012 12:34:03
 Re: new crawler. in reply to Stick welding, 12-13-2012 12:25:50
Sorry, that should buy not but and might as well.
