Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: new crawler.
Stick welding
12-13-2012 10:12:32
I'm VERY familiar with 5P+. It is Lincoln's improved 6010. Came out in the late 80's as a smoother running 5P which was the industry standard for decades. There is no such thing as 11010. The highest XX10 rod is a 9010 but most XX10 rods over 6010 are used almost exclusively for downhand pipeline welding. An XX10 would not be the rod to use to weld up anything on an undercarriage.
DGH
12-13-2012 10:20:02
 Re: new crawler. in reply to Stick welding, 12-13-2012 10:12:32
Well you better read the spec's for the 6010 5P= because it is a 11010 class rod!
Stick welding
12-13-2012 10:39:24
 Re: new crawler. in reply to DGH, 12-13-2012 10:20:02
I currently work...
in a welding supply store with the Lincoln welding consumables book right in front of me. The 6010 IS the rod classification!!! 60,000 psi tensile, all position with a cellulose coating. AWS classification E6010. I've also been a licensed interprovincial red seal welder for close to 30 years. I think you should have your facts straight before you try to correct anyone. LoL
mnoliverguy
12-15-2012 10:12:53
 Re: new crawler. in reply to Stick welding, 12-13-2012 10:39:24
Drama Queen still has a job?????????
DGH
12-13-2012 11:09:29
Well get yourself a 6010 rod and a 6010 5P+ rod and try to cut each on with some cutting pliers. You will find the 5P+ rod is much harder!! A normal 6010 rod and a 6010 5P+ rod are not the same!!
Stick welding
12-13-2012 12:25:50
 Re: new crawler. in reply to DGH, 12-13-2012 11:09:29
It's still a 6010 class rod. You don't measure the strength of a welding rod but how hard it is to cut with side cutters, otherwise you might as weld everything with hard facing rod.
Stick welding
12-13-2012 12:34:03
 Re: new crawler. in reply to Stick welding, 12-13-2012 12:25:50
Sorry, that should buy not but and might as well.
