International 500-C dozier, manufactured 60's ?
Michael VG
New User
We have a problem with it turning right. Also after operating for a while the right track will quit pulling. We have replaced both of the steering brakes, cleaned the steering clutch plates and greased the heck out of it. Still does the same thing. Any suggestions?
Would you mind explaining that again? I'm not getting why you're having trouble turning right when "after a while the right track stops pulling". The clutch should be released and the brake applied to the right track in order to turn right. Elementary, I know, but I'm not getting the drift of your problem.
Have you checked the pressure plates?
If I was going in there,I'd replace all the discs,the brakes & pressure plates too,plus tighten up any worn bits & pieces.
Steering linkages & adjustments are important too.
The best way I can explain it is after a while you get no pull from the right track. So when you you pull the left lateral the dozier just stops.
