Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: JD 450B
[Return to Forum]
WAYNE-N-TX
12-04-2012 06:34:11
4.226.114.46
I need to install new break bands on my JD 450B. I have it broken down where I can see inside the housing where the old ones are.
Now the question--can someone tell what I need to next. I was told all I had to do was worm the old ones off and the new ones on. Well, I can't see how to work the bottom. My book shows a spring on the bottom and I don't see how to get to it. Maybe I'm missing something. Thanks
[Reply]   [No Email]
nys
12-05-2012 03:02:35
98.15.254.212
 Re: JD 450B in reply to WAYNE-N-TX, 12-04-2012 06:34:11
Its been a few years but as I recall it can be done from the top, if you take out upper shaft of final drive brake drum and bands can be lifted out. I have the book in the shop if you need research done. Luck
[Reply]  [No Email]
DBer60!
12-04-2012 20:15:32
67.22.7.203
Roy is right, i have changed many from the top,just as Roy said. This applies to 450B. DON
[Reply]  [No Email]
Roy Suomi
12-04-2012 19:31:54
76.190.196.2
Nah.... It's not that bad.. The bands will come out without a lot of hub-bub..Those bands are 2 piece and can be removed by only taking the top linkages out.. Once all is disconnected , roll the bands so the bottom spring can be released. then roll the bands out.. Now , if it were a C series....That's something else.. Then you will have to remove finals, as they are one piece bands..When going back together, neverseize all the linkages so they won't freeze up over time..
[Reply]  [No Email]
WAYNE-N-TX
12-05-2012 19:44:22
4.225.169.157
 Re: JD 450B in reply to Roy Suomi, 12-04-2012 19:31:54
I’m not a mechanic, just trying to learn at an older age. I see what my book says but does not work for novices. I don’t know what “disconnect the upper linkage” is, sorry. I’ve worked on this today, loosen the bolts, one each side, that keeps the break band tight. The bands are loose now. What am I to do next?
[Reply]  [No Email]
sbogusta
12-04-2012 17:34:20
69.123.9.58
You will need to remove the final drives to gain accses to brake band assembly. which includes breaking the track
removing the final drives
and replacing any needed componants.
You cannot do this through the inspection cover on top.
[Reply]  [No Email]
LJD
12-05-2012 05:38:29
75.194.17.44
 Re: JD 450B in reply to sbogusta, 12-04-2012 17:34:20
In regard to the "modern" stuff, that only applies to 1010s, 350s and 2010s. All 450 series with dry clutches come out the top without removing the final drives.
[Reply]  [No Email]
WAYNE-N-TX
12-04-2012 17:54:21
4.90.63.130
Bad as I thought, I could see no other way. Thanks for telling me what I already had in my mind, all I need out of this machine is about 20 hours of work, cheaper to hire it done.
[Reply]  [No Email]
WAYNE-N-TX
12-05-2012 06:25:45
4.90.56.12
 Re: JD 450B in reply to WAYNE-N-TX, 12-04-2012 17:54:21
For sure I'll give it a try. I've gone to far just to put it back together. Thanks guys.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
