| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: 530ck backhoe
[Return to Forum]
| Author |
[Modern View]
| brian brooks
12-03-2012 02:32:09
173.17.71.242
Can somebody give me a idea what a case 530 gas backhoe with 2500 hours in central illinois is worth? Are the a good machine? Anything to look for or a reason to avoid? |
| Old Magnet
12-03-2012 11:09:09
99.24.163.9
Re: 530ck backhoe in reply to brian brooks, 12-03-2012 02:32:09
| Be shure to check for slop in the bottom swing tower pivot bearing and the amount of slop in the swing cylinder pins in the tower also....that seems to be the high wear points. |
| Case Nutty 1660
12-03-2012 05:16:37
75.127.24.27
| around here (NE Wyoming) they are in the 3500.00- 5000.00 range and up for a dsl model, a 530CK is a very good durable small utility unit, those hrs seem very low for a machine of that age if they are indeed correct that unit should run for many years yet with proper care, we sold many of them and I have seen them with 8000 hrs plus in the oil field before they traded them and these were used daily and hard then, if it has a torque converter drive you need to put it under load and determine if it is working correctly, it should have very good push power in 1st/2nd gear and be able to spin tires while say pushing into a dirt pile in 1st gear, if it has the mechanical shuttle shift make sure it shifts easy from FWD to REV and stays in gear under load, check fluids for condition a well maintained machine is easy to see, has it been greased are the pins in the backhoe/loader worn badly from lack of grease?, depending on what you are planning to use it for even if they have moderate wear the unit will still run/perform well and for many years, that being said the Case 530CK set the industry standard back in the day all others fought to acheive, give it a test drive and see if it will fit your needs good luck cnt |
| brian brooks
12-03-2012 11:07:22
173.17.71.242
Re: 530ck backhoe in reply to Case Nutty 1660, 12-03-2012 05:16:37
| Thanks for the reply it has shuttle shift and i didnt see caseomatic on it anywhere,does that mean no torque converter?Its gas all the paint and decals are there and look good. Do you know if parts are readily available? thank you very much case nutty. |
| Case Nutty 1660
12-03-2012 14:09:16
75.127.24.27
Re: 530ck backhoe in reply to brian brooks, 12-03-2012 11:07:22
| parts should not be a major problem, to tell if it has a torque convertor is easy it will have a lever on the right hand side of the steering wheel in the same spot as the throttle on the left side, and the clutch pedal will move very easy as it only moves a spool in a valve cnt |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
