TractorLinks.com
Re: Drott Skidloader
Stick welding
12-02-2012 13:55:37
When you lift up the front of the machine, does it creep down fairly fast? If it holds, it's not likely the cylinder seals that are the problem. If the seals in one or both cylinders were so bad that it wouldn't even lift the boom, they would also cause the boom to creep pretty fast when there was down pressure on it. Can you switch the hoses from the bucket valve to the loader valve and see if it will lift? That could help you determine if the valve was the problem. Putting a T in the hose and a pressure gauge would also help. Does the engine labor when trying to lift the boom? You could have a restricted hose or internal leaking in the valve body.
