TractorLinks.com
Re: Drott Skidloader
tpmx
12-02-2012 12:26:27
Thanks JM
never thought about that
I was convinced the problem was still in the valve.
Would the cylinders still work in the opposite direction?
It seems they have good pressure when running the loader down because they lift the machine right up .
Just wont run the opposite way at all.
It make sense,when I noticed the loader was running slower up i would run the loader all the way up and it would jerk like there was air in the system
After running the loader up and down a few times it would work ok for awhile
Stick welding
12-02-2012 13:55:37
 Re: Drott Skidloader in reply to tpmx, 12-02-2012 12:26:27
When you lift up the front of the machine, does it creep down fairly fast? If it holds, it's not likely the cylinder seals that are the problem. If the seals in one or both cylinders were so bad that it wouldn't even lift the boom, they would also cause the boom to creep pretty fast when there was down pressure on it. Can you switch the hoses from the bucket valve to the loader valve and see if it will lift? That could help you determine if the valve was the problem. Putting a T in the hose and a pressure gauge would also help. Does the engine labor when trying to lift the boom? You could have a restricted hose or internal leaking in the valve body.
