id case 450 pads
got tracks on ebay.nice pads pins turned.2 links short so i used 2 from old chain.any way im a couple pads short.the bolt pattern on my old 450 chains are even,while the newer chain pads are 3-1/4" and 4" bolt hole centers.they are 12" pads 1/2" holes.
hi jd. see what you got looks like ill need 2 for the side i put on and 2 from the side i robbed.but i added 2 links from my old chain would like to get 2 links from the chain that matches those pads.what am i looking at in years.my chain matches my parts book which is a early 450.the pads on the new chain must be newer.
You are right yours is the early series and you did get chain with pas for newer series.I am not sure though my pads might be . Mine may not be the flat loader pad , they might be the Open centre Grouser. I will check tomorrow since my shop is 20 kilomtre away from my house. he reason I have a few parts left is because I had a Case dealership for 37 years and now moving left over. jc
(quoted from post at 09:44:25 11/25/12) You are right yours is the early series and you did get chain with pas for newer series.I am not sure though my pads might be . Mine may not be the flat loader pad , they might be the Open centre Grouser. I will check tomorrow since my shop is 20 kilomtre away from my house. he reason I have a few parts left is because I had a Case dealership for 37 years and now moving left over. jc
k
I made a mistake I do have two left but they are 14 and one is street pad and the other is open crouser If you e mail me your e mail I can send you pictures of them they are new. jc marleau
looks like i might of got jd 450 chains.other than the bolt pattern they seem to work.the 2 extra links were ok.the sprockets i got were case.check out the picture and look at the offset bolt pattern,see if im missing something.thanks.
