John Deere 350C Track Adjuster Needed
1970-1655
I just bought a 1978 John Deere 350C dozer. The right side track adjuster is bent , rusted and stuck. Does anyone have a good used one or know of a salvage yard that might?
350C piston has a different type seal on it then an older 350. Parts can be swapped back and forth and if wanted - the 350 piston can get the seal groove enlarged so the better 350C neoprene seal fits on it.
Check if the local JD dealer is part of the used parts network. They should be able to find you a good used one.
