Ran d4 out of fuel
wilson ind
Brain fart Ran D 4 traxicavitoy Basicly D4 with 5 rollers and loader out of fuel. Neighbot says hold rag and air hose in fuel tank crank starting motor with decompression open. Will this work with out harm?
the best way to bleed it is cut an old tire tube with the valve on it. place it over the fuel tank opening and clamp it. pressurize to 5 or 10 psi and then open every bleeder valve to your injection pump. then crack the injector lines and you should have most of the air out.
Loosen injector line's and turn motor over until fuel comes out. Also pump should have a way to pump fuel up to get air out of system. There is a round knob on pump, loosen it(turn left) and it will come up so you can pump up pressure.Loosen lines if it has a way to pump.After you get it running and it doesn't run right you can loosen lines at injectors and get all air out system.You can tell when the fuel has no air in it.
I used a shop vac hose on 'blow' stuck in the tank with a rag wrapped around it, worked fine. You don't want a lot of pressure in there for sure -
If you fill the tank completely full it will bleed by gravity. Open top filter tower bleeder until fuel runs then open each bleeder behind individual injection pumps.
thanks filled tank completely full gravety through 2 filter bleeders cracked injector lines getting furl and air will open individual bleeders friday appreciate all the help from all Bill
