Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JDE Marris Case 310 final drives
LJD
11-15-2012 05:50:06
If I said that I "mispoke" digitally. I thought I said no "steering clutches." The Case 310 uses a Clark transaxle- pretty much the same as what Oliver uses in HGs, OC3s, and some OC4s and in Terratracs. No steering clutches, just two wet brake bands. I say "some" for the OC4 because the OC4 had a choice of two different steering/drive systems. The "Spot Turn" system DID have clutches but it is a wet-clutch system as I recall.
A big problem with old crawlers with dry steering cluthes is they get can stuck when sitting around. Like use in Deere crawlers up to through the 350B or 450B series, Allis Chalmers HD3 and HD4, etc.
LOU from Wi.
11-15-2012 11:18:56
 Re: JDE Marris Case 310 final drives in reply to LJD, 11-15-2012 05:50:06
Thanks LJD.I thought the Impossible, like HYd pressure that would be similar to a BOB cat 726. Chain driven or such.My SIL has a large 3 port garage that is surrounded on 3 sides with clay soil,he wants to remove. In other words the building was erected in a small hill side. Water, snow lays on the cement block(4 courses)then wood framed the rest of the way up.Now he is interested in a small dozer he can use to dig out around the garage.He is terribly hard on anything mechanical so lending out our stuff is out of the question. So we will keep looking for one unit that can, and that he can work on. Thanks Again .Warmest regards LOU.
Mike M
11-15-2012 11:59:45
 Re: JDE Marris Case 310 final drives in reply to LOU from Wi., 11-15-2012 11:18:56
I think I'd want a small excavator to dig out around a garage. Load dirt/rock in a truck and haul it off too.
LOU from Wi.
11-15-2012 20:44:27
 Re: JDE Marris Case 310 final drives in reply to Mike M, 11-15-2012 11:59:45
Thats worth thinking about. His choice ofcourse. Will suggest that to him as an alternative for him to consider. Thanks for the reply. LOU.
Copyright © 1997-2015 Yesterday's Tractor Co.
