TD6 crawler/dozer
Darryl 2 Ms
New User
Hey guy's, just scored a 1946 TD6 with a factory winch on the back. Anyone know if there is a regular pto shaft under there if I pull off the winch? Would like to use the winch in winter for logging and maybe use the pto in hay season to run a baler on some steep hay fields.I figure the weight and the low center of gravity would be a plus. thanks for your help!
Um!
I think you need a gearbox to get 750 rpm for standard pto speed.
Unfortunately we just junked one but post from Aus wouldn't have worked.
Bailer with motor would be best solution and proably easyer and cheaper to find. They tale a special reduction pto box to get down to 540
