Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Need to remove several trees. How?
[Return to Forum]
812 Farmer
11-13-2012 07:43:39
184.9.208.39
Need to remove several (50+) small trees (3/4" - 2") range. Anyone have any good ideas for doing this? Backhoe to dig them out? Small dozer? Skid loader with tree puller attachment? Thanks.
[Reply]   [No Email]
jonstark
12-16-2012 16:09:47
71.127.5.101
 Re: Need to remove several trees. How? in reply to 812 Farmer, 11-13-2012 07:43:39
Consider finding a "grubber". It grabs the trunk of whatever and if you hook it to the lip of your loader bucket it'll lift out the whole plant. This works really quickly if you have someone on the ground moving it from tree to tree while you move the tractor.
Another way to grub is to set up a triangle of angle iron with a skidding chain draped over a notch in the top. One end goes to the grubber and the other to whatever you're pulling with. Properly rigged it can leverage the pull forces and you don't need to get near so can be done in tight surroundings.
jon
[Reply]  [No Email]
Pops1532
11-13-2012 12:05:32
98.227.131.18
 Re: Need to remove several trees. How? in reply to donjr, 11-13-2012 07:43:39
I've pulled out trees bigger than that with my pick up.
[Reply]  [No Email]
kevinsstuff
11-13-2012 11:21:44
66.87.7.59
i used my case 530 with front end loader to pull out
box elder 2 to 6" just wraped chain around base of tree
and hook to draw bar as short as u can .pulled them
out root and all. but for the bigger ones or where some
where grown toghter.i had to dig down with bucket.also
used bucket about 1 to 2/3 height of tree and pushed
them till they broke or pushed somwhat over. then
used chain to pull out
[Reply]  [No Email]
LOU from Wi.
11-13-2012 10:54:42
174.124.1.203
812 Farmer Bought the heavy steel blade from Northern Tool,use it to dig out trees and shrubs for transplanting. use it on the tractor , Bobcat, dozer. will use it again in the spring to dig trench for power line to tractor shed. Second picture of root cutter we made to fit Bobcat, works great also.Surface roots easily cut. Hope this helps LOU.
[Reply]  [No Email]
812 Farmer
11-13-2012 16:11:33
184.9.208.39
 Re: Need to remove several trees. How? in reply to LOU from Wi., 11-13-2012 10:54:42
Thanks for the pictures LOU. I had not seen a spade like the one you had but looks like it might work.
[Reply]  [No Email]
LOU from Wi.
11-13-2012 19:47:50
174.124.1.203
 Re: Need to remove several trees. How? in reply to 812 Farmer, 11-13-2012 16:11:33
Here's a link for you, the spade works good for us.They became cheaper (price)than when we bought ours. Hope it helps.
LOU
[Reply]  [No Email]
812 Farmer
11-14-2012 06:27:34
184.9.208.39
 Re: Need to remove several trees. How? in reply to LOU from Wi., 11-13-2012 19:47:50
LOU, was wondering what lifting capacity would be necessary for this quick spade to be effective?
[Reply]  [No Email]
LOU from Wi.
11-14-2012 13:28:12
174.124.1.203
 Re: Need to remove several trees. How? in reply to 812 Farmer, 11-14-2012 06:27:34
812 Farmer, I can't say what presure works best, I can only tell you what we use with our equipment. Our Bobcat 722 has a 1700# tip cap, a 1200# lift cap. The Oc 46 has around a 2000# cap lift.
The 706 I can't say what either the lift or tip cap is on it,never took the time to find out.
We found out with both Bobcat and dozer on bigger trees, if you go around it with the digger to loosen the soil and cut a root ball type base to the tree, it helps for transplanting of them. For getting rid of small stumps and trees, just break the soil out in front of the stump/tree and go to the back of the stump/tree sink the digger usually pops right out.Those trees were not for transplanting,just removal. We've done some Oak-alot of Popple and others up to 8-10 inch at the base.
Like you could see, for us it is handy for ditch,trench digging, or in warmer climates, water line burial.Hope this helps.
LOU
[Reply]  [No Email]
Diydave
11-13-2012 10:42:27
96.244.153.238
Try small, for that few trees,
[Reply]  [No Email]
oldtanker
11-13-2012 10:29:43
66.228.255.239
Dozer with a root rake should take out the sizes you mention fairly fast.
Rick
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
