Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Hough transmission
Bill in il
11-09-2012 06:42:16
Ok so you have me almost convinced its not in the converter. I need to let the machine sit outside overnight and see how it respnonds to the transmission test again. The thought about a internal drag of some sorts sounds interesting. That oil is used for holding the clutches together but what else are they used for inside the transmission? Anything? I need to find another gauge lower than the 5000 psi one i have before I can test that.
I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal.
Dr. Walt
11-11-2012 05:40:58
 Re: Hough transmission in reply to Bill in il, 11-09-2012 06:42:16
Hi Bill, this problem of yours has just about got me stumped. You stated: "I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal." Is there a "vent line" fitting or a "pressure" fitting? If it IS a pressure fitting, have you tried applying air pressure to it to see what happens - both at rest & while operating?
DGH
11-09-2012 09:54:16
The control oil pressure is generaly used for operation the drive clutches and pressure lubrication of bearings etc. Now I have not worked on the one you have, so don't know what the air would be used for. Maybe a holding brake when the transmission is in neutral? You need to get a manual for that machine. But in my experience you have an unusual problem.
Those types of transmissions usually have a foward and reverse clutch pack and one for each speed. So for any speed you need to operate one of the direction clutches and one of the speed clutches and all the others are off. I once found a piece of rubber from the inside of a hose in the valve body. That caused erratic opertion and that was really hard to find.
It sound like yours does not fully go into gear, so that is why I think it is a control issue.
When it is slugish does the engine rev freely and the machine not move or is the engine loaded and the machine not move?
