Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: Hough transmission
[Show Entire Topic]  [Return to Forum]
Bill in IL
11-08-2012 13:37:30
132.3.49.68
I have owned this machine for 2 years or so now. It has always been this way except the not wanting to move on startup that has been recent. I have put about 150 hours on it in that time so I don't think its something that is serious I just wish it was a little stronger.
I have never paid attention to the converter pressure at startup. Will do that later. I usually do not see the converter temp guage move much unless I do a lot of hill climbing. I was going to take apart the transmission regulator. Maybe its letting too much flow through it and not getting to the converter.
Yes the engine sounds fine hot and cold. It will load the engine if I have it in high gear and give it full throttle. I just wonder if it loads the engine like it should. The tachometer is long gone in this machine. I have driven other machines like my old michigan and a deere 544E those machines drive much better than the Hough. I usually am always at full throttle to make it move the way I need it to move where as other machines I do not have to do that. In temps say 30 degrees and below 3rd gear is unusable. I usually road travel in 2nd cause there is no increase in speed to use 3rd unless going downhill. Maybe your right this machine needs to retire to florida.
[Reply]   [No Email]
DGH
11-08-2012 20:11:32
72.25.192.4
Re: Hough transmission in reply to Bill in IL, 11-08-2012 13:37:30
If your convert er temp goes up when hill climbi ng and returns to normal when not, then I would think it is getting the proper oil supply. If it were hot all the time that would be different. The converter must be full of oil all the time, if it was straved of oil and not full it would soon destroy itself. I would go back to the transmission control. There should be ports for checking the pressure on each clutch pack. Put gauges on all of them and see that they go to full pressure when in use and turn to zero when not. You may have a leak that allows partial pressue to a clutch when it should not have any causing an internal drag in the transmission. That is the only thing I can think of that would cause your strange problem.
  [Reply]  [No Email]
Bill in il
11-09-2012 06:42:16
216.24.116.183
Re: Hough transmission in reply to DGH, 11-08-2012 20:11:32
Ok so you have me almost convinced its not in the converter. I need to let the machine sit outside overnight and see how it respnonds to the transmission test again.
The thought about a internal drag of some sorts sounds interesting. That oil is used for holding the clutches together but what else are they used for inside the transmission? Anything? I need to find another gauge lower than the 5000 psi one i have before I can test that.
I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal.
  [Reply]  [No Email]
Dr. Walt
11-11-2012 05:40:58
12.2.223.79
Re: Hough transmission in reply to Bill in il, 11-09-2012 06:42:16
Hi Bill, this problem of yours has just about got me stumped. You stated: "I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal." Is there a "vent line" fitting or a "pressure" fitting? If it IS a pressure fitting, have you tried applying air pressure to it to see what happens - both at rest & while operating?
  [Reply]  [No Email]
DGH
11-09-2012 09:54:16
72.25.192.4
The control oil pressure is generaly used for operation the drive clutches and pressure lubrication of bearings etc. Now I have not worked on the one you have, so don't know what the air would be used for. Maybe a holding brake when the transmission is in neutral? You need to get a manual for that machine. But in my experience you have an unusual problem.
Those types of transmissions usually have a foward and reverse clutch pack and one for each speed. So for any speed you need to operate one of the direction clutches and one of the speed clutches and all the others are off. I once found a piece of rubber from the inside of a hose in the valve body. That caused erratic opertion and that was really hard to find.
It sound like yours does not fully go into gear, so that is why I think it is a control issue.
When it is slugish does the engine rev freely and the machine not move or is the engine loaded and the machine not move?
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
