TractorLinks.com
Re: 977 h caterpillar idler wheels
Robert Plumadore
11-06-2012 07:35:55
Your idler is probably runing outof line. the shims under the side plates can correct this. cut a 2 or 3 inch hole on the side of the idler then weld up the crack and then add on to the center until it is back to center and add passes to both sides until it is back to the original diameter. I have did many cat idlers on the machine, break the track and run the idler out past the end ofg the track. I did a set n a 973 about 6 months ago. a magnatic ground helps you an turn the idler without having to unhook the ground clamp
