Hough transmission
Bill in IL
I have an old Hough H60B articulate loader. Its probably from the early 70's vintage.
Transmission has always been slightly weak. On the hottest days of the year the machine runs great its responsive and has great power. As the outdoor temps cool it (torque converter) gets sluggish and weak whereas high gear is unusable. It improves as the machine warms but still not great. I have it in the shop to attempt to look at this but not sure where to go. I am thinking its a restriction in the charging pump circuit or maybe just a weak torque converter.
Several times this fall after I started the machine it would not move. After shifting forward to reverse 6-8 time it slowly inched forward and began to move more and more until it moved normally. After I got it moving it was fine for the rest of the day. Not sure if that is related to the overall weak transmission or another problem.
The manual explains how it works and how to rebuild it just doesn't say much about troubleshooting. Can these torque converters be rebuilt? Is it O rings and gaskets or what really wears in a torque converter?
sounds like some seals have hardened up on you and bypass fluid till they warm up and get flexible...i have had great results with K&W TransX...it comes in a blue and silver quart container...cant tell you how many transmissions i have gotten another 20-30 thousand miles out of.
some folks will say its snake oil,but sounds like you dont have anything to lose trying it.
Check the WEIGHT (viscosity) of your trans fluid, it sounds like you may have too heavy a weight fluid in your trans - ie: when it's cold, fluid is heavy & sluggish, but as it warms up & becomes thinner the trans works fine.
Sounds exactly like my old Trojan last winter - I have no idea what oil was in it, but it was pretty bad. New ATF type A this past summer, it's like a new machine.
Oil was changed a year or two ago. About 100 operating hours with dextron ATF. Cleaned the sump at that time overall the transmission was pretty clean at that time.
Usually when that type of transmission goes bad it shows up when hot not cold. I am thinking like you that there is a restriction some where. Maybe a plugged filter or a collapsed suction line, or a crack in a suction line letting air. Maybe take the pan off and check the oil pick system. I bet it is a simple problem but may not be easy to find. If it runs well hot there can't be anything major wrong!
Good morning,
My first thought was too heavy oil also but you have used the right stuff.
The other replies are also valid like a suction leak.
You did not mention pressures at all. Main (clutch) pressure should be 160psi-180psi. You should have this in neutral, in any gear, at idle or hi idle. Do you know what the pressures are? Does the machine have a gauge on the dash? If no gauge you can tap in a gauge at a pipe plug on the selector valve on top of the transmission. This is the main pressure port. Use a 300-500psi gauge, not one that goes to 3000 or something.
Another thought has to do with the selector valve. It has three spools, a F&R spool, range spool and a declutch spool which is activated by the left brake if it is still stock. The shift spools are probably ok if the detents feel good but maybe a problem in the declutch spool. Disconnect the line to it, some were air, and try it. If the declutch spool is not moving properly it will not allow pressure to get to the clutches.
Torque converters are rebuildable but probably not your problem.
good luck and keep us posted on progress
Dennis
Clutch pressures are in the 160 to 180 range as you describe. There is a guage on the dash to show that. Even when the machine will not move on startup clutch pressures are in range. The brakes do not work but the declutch pedal will take the transmission out of gear.
I think the problem is more related to the torque converter side of the transmission. I would describe its operation as sluggish and it takes about half throttle to make it really move. I have an old michigan 75a that responds to throttle much better than this machine. Shifting is normal and I can feel detents though probably worn as can be expected.
I think the suggestion of a suction leak or collapsing suction line are possibilities. Any suggestions on determining a suction leak or collapsed line? When I crawled under there they all seemed round and hard with age no bad ends or leaks from those hoses. It will be a healthy expense to replace all the lines in that circuit cause they are 1.25 to 1.5 inches in diameter so I don't want to go throwing parts at it.
I will give it a closer look tonight. Maybe drain the transmission and check suction hoses closer.
I remember one day this fall I drove down a steep hill and could not get back up it till the machine warmed up a little more. I gave it full throttle and it could only go up half the hill till about the 3rd try.
Well if your oil pressure is steady under all conditions that would tend to rule out a suction problem. That would bring me back to looking for control issues that were mentioned before.
A torque converter is a simple device and they either work or not, and temperature does not have a lot to do with it.
Hi Bill,
Now that we know you have good clutch pressure I'll give you another test.
Apply the brakes using the right pedal or put the machine against a bank so the wheels will not turn. Try each gear, the driveline between the converter and transmission should not turn while doing this no matter what the rpm as long as the wheels do not spin. Driveline should spin free in neutral or when declutching. If everything is tip top you may not be able to hold it in 1st gear. If driveline spins when doing this you may have clutch pack problems but unlikely they would all be bad.
Forward clutch is common to all three forward gears and rev clutch is common to all three reverse gears.
The internal workings of the converter usually work or not work.
Let us know what you find
good luck
Dennis
I took the machine out of a heated shop tonight. It was 70 degrees so this may not have been the best test for my situation cause like I said the warmer the machine is the better it works. I butted up to a slab of concrete and gave it full throttle in all forward gears. The input shaft to the transmission did not turn any without the wheels turning. This should rule out the transmission right?
It does make me question where does the transmission clutch pressure come from?
Do you have any more suggestions on where to go with this.
Morning Bill,
Sounds like your transmission is good as long as it reacts the same when cold.
The pressures come from a pump mount on or in the converter. It draws oil from the trans sump, sends it to a regulator and back to the transmission selector valve. Oil that the main pressure system does not need goes to the converter.
Problem is, it has been sooooo long ago that I can't remember the layout of the converter assemble for sure on the H60B. Hough used that transmission in a lot of different models but I don't think the converters were all the same on different models. There is going to be a main pressure regulator mounted some where and a converter regulator some where but I can't remember where. Your problem may be related to converter pressure when cold.
Could you post a picture of the back of the converter and a picture of the converter side of the transmission? This may jog my memory.
Otherwise, as another poster stated, mechanical failures of a converter generally don't come and go and problems are usually when hot not cold.
Dennis
Thanks for your time. Your just the man I have been looking for... someone with previous experience on these machines.
I will attmept to take some pics and post this evening. Its pretty crowded in there with hoses so hopefully you will be able to see what you need. I know there is a regulator right on the back of the converter charging pump but will have to look in the book for what its exact purpose is.
Thanks.
Did some more checking tonight. I found the converter pressure regulator. I pulled it out and found nothing out of the ordinary. It was clean and both springs were intact.
I took some pictures of the torque converter. Lots of stuff in the way but the torque converter regulator is right above the temp gauge for the converter on the left side of the machine. The charging pump is right below the transmission regulator. The oil for it comes out of the transmission to the charging pump to the filter then to the transmission regulator.
Morning Bill,
The pictures turned out fine but for right now I am at a lose, it just doesn't make sense.
I'm thinking your machine just wants to sleep in a nice warm bed.
Internal components of the converter are probably aluminum and if they fail do to a bearing or something your oil should have a silver color to it.
I can't think of anything in the torque that would be temperature sensitive as you describe it. Sorry
Thinking out of the box a bit here. Does the engine sound the same when cold or hot? Do you have a hydraulic load for some reason when cold robbing your power. Can't think of one myself.
Does the clutch pressure jump right up when started cold or is it slow to build? Ever any over heating problems with the conv/trans system?
Sorry I'm not more help but running out of ideas.
If you come up with anymore clues let us know, I'm interested in helping if I can.
Dennis
I have owned this machine for 2 years or so now. It has always been this way except the not wanting to move on startup that has been recent. I have put about 150 hours on it in that time so I don't think its something that is serious I just wish it was a little stronger.
I have never paid attention to the converter pressure at startup. Will do that later. I usually do not see the converter temp guage move much unless I do a lot of hill climbing. I was going to take apart the transmission regulator. Maybe its letting too much flow through it and not getting to the converter.
Yes the engine sounds fine hot and cold. It will load the engine if I have it in high gear and give it full throttle. I just wonder if it loads the engine like it should. The tachometer is long gone in this machine. I have driven other machines like my old michigan and a deere 544E those machines drive much better than the Hough. I usually am always at full throttle to make it move the way I need it to move where as other machines I do not have to do that. In temps say 30 degrees and below 3rd gear is unusable. I usually road travel in 2nd cause there is no increase in speed to use 3rd unless going downhill. Maybe your right this machine needs to retire to florida.
If your convert er temp goes up when hill climbi ng and returns to normal when not, then I would think it is getting the proper oil supply. If it were hot all the time that would be different. The converter must be full of oil all the time, if it was straved of oil and not full it would soon destroy itself. I would go back to the transmission control. There should be ports for checking the pressure on each clutch pack. Put gauges on all of them and see that they go to full pressure when in use and turn to zero when not. You may have a leak that allows partial pressue to a clutch when it should not have any causing an internal drag in the transmission. That is the only thing I can think of that would cause your strange problem.
Ok so you have me almost convinced its not in the converter. I need to let the machine sit outside overnight and see how it respnonds to the transmission test again.
The thought about a internal drag of some sorts sounds interesting. That oil is used for holding the clutches together but what else are they used for inside the transmission? Anything? I need to find another gauge lower than the 5000 psi one i have before I can test that.
I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal.
Hi Bill, maybe we'll get this resolved yet. Removing the torque on speculation is a lot of work and a decision you will have to make. If you do and find the problem there I would be very interested in hearing about it. There is a reason the machine is doing what it's doing.
DGH's thoughts on checking individual clutches may be a good idea. There are plugs at the shaft manifolds for that. I believe 1/8'' pipe.
The transmission and the gear train portion of the converter should be vented. If they are not maybe a vacuum is being developed. Sometimes the vents were joined by a line like the one you mentioned. Could be what it was. Check to see if they are vented or have they been plugged. The one on the transmission was small, I think 1/8'' pipe. The larger plug on the top of the trans was not the vent unless changes were made in later years.
Clutch pressure is only used for clutch engagement, then the converter gets satisfied and the remainder is used for transmission lube.
Interesting problem
Dennis
The control oil pressure is generaly used for operation the drive clutches and pressure lubrication of bearings etc. Now I have not worked on the one you have, so don't know what the air would be used for. Maybe a holding brake when the transmission is in neutral? You need to get a manual for that machine. But in my experience you have an unusual problem.
Those types of transmissions usually have a foward and reverse clutch pack and one for each speed. So for any speed you need to operate one of the direction clutches and one of the speed clutches and all the others are off. I once found a piece of rubber from the inside of a hose in the valve body. That caused erratic opertion and that was really hard to find.
It sound like yours does not fully go into gear, so that is why I think it is a control issue.
When it is slugish does the engine rev freely and the machine not move or is the engine loaded and the machine not move?
Yea I am going to have to round up some a guages to check those pressures. I would like to trace down the problem just to rule out something simple. If it involves pulling the transmission or the torque I probably will defer that till a later date and run it the way it is. The more I get into this though and read in the manual and what you guys say it does seem really weird that it shows up when cold. Starting to wonder like DGH said that maybe a clutch is dragging. I will let it sit out of the shop tonight and see how it reacts in the morning.
Hi Bill, this problem of yours has just about got me stumped. You stated: "I also see there used to be an airline connected to the top of the transmission what is the purpose of that? It's not the airline for the transmission disconnect or the one connected to the brake pedal." Is there a "vent line" fitting or a "pressure" fitting? If it IS a pressure fitting, have you tried applying air pressure to it to see what happens - both at rest & while operating?
Today I was out running the old machine around moving some manure and pushing a few trees.
I always noticed that the needle on the transmission pressure gauge bounced a lot but never gave it much thought. I have noticed now that when I have it in gear (any gear) and give it throttle it will peak up to 200 psi (needle steady) then 3-4 seconds later I start to hear a sound like compressed air (thinking air in the charging pump or converter?) and the needle will drop off to 180 or so and start bouncing again. Starting to wonder as mentioned earlier if I don't have a suction leak or restriction in the suction line to the charging pump. Overall today it ran good but the air temp was 65 degrees. It was slow to move on startup again for the first few feet of movement. I think as the weather cools I will be able to get this figured out.
Thanks Bill for reporting back. A bouncing needle means cavitation. And you are right, suction issues. Check the vent on top of the transmission for being plugged. Some of the Hough machines had a check valve built into the suction strainer to keep the oil from returning to the sump from the pump during shut down. Possible problem there if your machine has that style. Another experiment could be adding extra oil to the system. Should be checked at idle in neutral.
I don't think you have serious problems if it works ok sometimes.
good luck
Dennis
This morning I finally got some cold weather and the machine sat outside overnight. The new tank heater i put on works but now the ether doesn't.
After getting it started it would not move as expected. Transmission pressure gauge shows 150 psi. I put the machine in neutral and checked the driveshaft from the torque converter to the transmission and at full throttle it was not turning. I will get an appropriate gauge on order this week for checking pressures on the transmission.
Anyone have any good suggestions on where to go from here. I know pressure readings would be a big help at this point.
Well Yesterday you reported peak pressure of 200 dropping to 180 and bouncing. Now when cold only 150. Usually it is highest when cold! Sure looks like you have a suction problem!
