| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: John Deere 350 clutch oil leak.
[Return to Forum]
| Author |
[Modern View]
| Ken Knopp
10-30-2012 17:58:44
207.216.52.239
I have a John Deere 350 c. It is leaking oil from the steering clutch back into the pinion gear housing through the bearing. All the seals and O rings have been changed and it hasn't stopped the leak. It is leaking through the bearing and into the ring and pinion gear housing. Can't see anywhere that it could leak. |
[Reply] [No Email] | |
| LJD
10-31-2012 06:15:23
75.194.112.184
Re: John Deere 350 clutch oil leak. in reply to Ken Knopp, 10-30-2012 17:58:44
| Obviously you must of missed something. The dry clutch machines were not a big problem as long as the ring-gear carrier was shimmed correctly. But with the wet-clutch Cs - they were chronic leakers. When the Cs came out - the reversers and steering clutches took up most of our repair schedule. I'd check again for any imperfections in metal parts where pistons seal and where steel tubes plug in to o-rings. |
| Ken Knopp
11-02-2012 08:59:33
207.216.52.239
Re: John Deere 350 clutch oil leak. in reply to LJD, 10-31-2012 06:15:23
| Do the bushings play a roll in sealing the clutch pack? They may be a bit worn, that is the only part I did not change. |
| BCnT
10-30-2012 20:33:22
68.65.150.242
| i had a similar problem with my 350B leaking from the finals onto the dry clutches...third time back in the shop the owner did the work...found the JD seals were a tad loose...he used Cat seals and put em in piggyback...2 seals per side...hasnt leaked since...mite be worth looking at when you tear it back down. |
| Ken Knopp
10-30-2012 21:47:14
207.216.52.239
Re: John Deere 350 clutch oil leak. in reply to BCnT, 10-30-2012 20:33:22
| I think you are right for a B model, mine is a C with wet clutches, I had the same problem with my older B model and traded it in on a C to get away from dry clutches but found different challanges, thanks for the info. |
| AJJ
11-05-2012 11:03:28
70.192.217.224
Re: John Deere 350 clutch oil leak. in reply to Ken Knopp, 10-30-2012 21:47:14
| Have you checked the o-rings under the steering control valve? It can leak through the top of the transmission case where it covers the opening of the ring gear. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
