Yesterday's Tractor Co.
Shop Now View Cart
Re: 977 h caterpillar idler wheels
10-29-2012 20:14:16
Most guys have never seen a 3/16" rod, and don't have a power supply with nearly enought amps to burn one. That being the case, a couple of passes with a 1/8" 7018 more than likely won't build as much heat as one pass with the much larger rod. That said, yeah, I know what your saying but my thoughts were that a hole cut and then welded back up by some one that doesn't do alot of cutting and welding would tend to be more of a problem (read new crack waiting to happen) than just not worrying about it. If it were me I'd much rather drill a small hole. In this case 1/4" diameter should be a gracious plenty as a vent, and much easier to weld up than a plate cut out of the side. Too a small hole is far less likely to propulgate a crack due to the round shape than a torch cut hole.
Stick welding
11-06-2012 10:08:28
 Re: 977 h caterpillar idler wheels in reply to NCWayne, 10-29-2012 20:14:16
The patch doesn't need aNy strength. It just keeps dirt and water out of the idler. If someone has enough skill to build up the idler, they can weld the cut out back in.
